MWI not working - after patches
We installed the IIS patch (Q319733_W2K_SP3_X86_EN.exe)<br><br>and Callmanager patches:<br>install win-OS-Upgrade.2000-1-3.exe <br>installed win-OS-Upgrade-2000-1-3spA.exe<br>installed win-SQLservicepack3.1-0-2.exe<br>installed win-MS02-007.exe<br>then installed cisco2.3-1-3a-es10b.exe<br><br>Not sure when the MWI stopped working, but after doing all the above, can't get MWI working <br>Tried many of the standard work arounds - no help<br>everything seems to be working<br><br>any ideas ???<br><br><br><br>
Anonymous
N/A
Re: MWI not working - after patches
Are there any errors in the Unity server's application log?What are the Unity and AvSkinny.tsp versions? Do the lamps not go on? Off? Both?
Steve Olivier
Software Engineer
Cisco Systems
Anonymous
N/A
yes the MWI lights go on and off manually
the TSP version is 6.01 (CM-TSP - latest)
problem appears to be in switch/ports
shows under SWITCH
Active Switch is Cisco Callmanager ....
Set Active Switch Type = Avaya .... no PBX integration
Shows under IP SWITCH
Active Switch Settings is Callmanger ...
Set Active Switch type = Cisco, Callmanager,3.0(1) or later, Tapi
Ports show
Cisco - Callmanager port 0 through 0 (first port set)
Cisco - Callmanager port 1 through 4 (second port set)
all set for MM, MWI, etc
i would think the first set of ports would be identified as PBX switch type
setting the ports to first set and saving(0 - 0 to 1 -4 and second set to 0 -0), then setting them back to second port set (1-4 from 0-0) and saving appears to have made it work again.
88
