MWI port ratio
Does anyone know what Cisco suggests as a baseline for assigning MWI ports? What is the ratio of ports that should be assigned to only do MWI? I understand that this will depend on call volume and you might need to play around with it. I'm looking for baselines. For instance, out of 32 ports, how many should be assigned for MWI (only) to start?
Jason Wydra
Re: MWI port ratio
That depends quite a bit on the switch integration you're using - if we're doing MWIs via analog calls they'll go _quite_ a bit slower than if they're being done digitially (i.e. as with CM) - and of course with serial integrations it's not an issue.
What kind of switch integration are you talking about here?
Re: MWI port ratio
This is a Call Manager/Unity integration. Centralized call processing. Digital MWI.
Thanks.
Re: MWI port ratio
The integration guide for CM contains a section on port planning that covers the base reccomendations - you'll find all the integration guides for all switches for Unity 4.0(x) here:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/integuid/index.htm
Look for a section titled "Planning How the Voice Messaging Ports Will Be Used by Cisco Unity".
In the case of CM, MWIs are sent out very fast and the need for more than one per CM cluster is probably pretty rare I would think.
122
