Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
MWI's continually going out of synch - system wide
Unity 3.1.3/Exchange2K
MWI's have continusously gone out of synch (not on when user has vm, not off when messages checked).
Tried patches, upgraded to 3.1.3 per TAC recommend, tried resynch now in Unity admin under "switch". Recurring system-wide issue. Please help.
Re: MWI's continually going out of synch - system wide
Often times complex troubleshooting issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
A thought. Are you running the most current version of the TSP? 6.x?
Also, I had a simular problem for which I thought was a MWI sync problem but it was really a Time od Day for MWI presentation problem in the Unity setup.. Is this a new install or an existing?
There's a bunch of things to look at:
http://www.cisco.com/warp/public/788/AVVID/Unity_MWI_Exchange.html
http://www.cisco.com/warp/public/788/AVVID/cm_mwi_config_issues.html
If you've gone through this, you may want to post your question on the Unity3.x discussion forum, which will have a much wider audience for this kind of problem. Also, please specify what switch (callmanager or whatever) you're integrating with.
106
