Name Display not working with Lucent 5ESS and Call Manager 3.2
Our PSTN Connection goes to Sprint’s 5ESS Switch using the 6608 Module in the 6509 (NI2 ISDN Variant). Now, Calling Name is giving us some troubles in both directions. Calling Number does work.
CallManager sends the Calling Name to the PSTN using an optional IE the “display IE” (0x28). The Sprint 5ESS Sends the Calling Number, Called Number and Name Display using a Optional IE called the “Facility IE” (0x1C) with the information encoded in “ASN.1”.
Strange thing is that we can decode Caller ID in both directions (Number only) but no Name. Is there anyway to make call Manger send the name display using the Facility IE? Or is there a better ISDN Variant to use when connecting to the Lucent 5ESS? I have included the “SETUP” messages below for your reference captured with Sniffer T1 Module:
5ESS To the CallManager:
DLC: ----- DLC Header -----
DLC:
DLC:
DLC: Frame 15 arrived at 14:07:48.6166; frame size is 67 (43 hex) bytes.
DLC: Destination = DTE.D
DLC: Source = DCE.D
DLC:
LAPD: ----- Link Access Procedure D (LAPD) -----
LAPD:
LAPD: Address byte #1 = 02
LAPD: 0000 00.. = SAPI = 0
LAPD: .... ..1. = Command/Response bit
LAPD: .... ...0 = EA
LAPD: Address byte #2 = 01
LAPD: 0000 000. = TEI = 0
LAPD: .... ...1 = EA
LAPD: Control byte #1 = 3E
LAPD: 0011 111. = N(S) = 31
LAPD: .... ...0 = I (Information transfer)
LAPD: Control byte #2 = 3A
LAPD: 0011 101. = N(R) = 29
LAPD: .... ...0 = Poll bit
LAPD:
ISDN: ----- ISDN Call Control (Generic Q.931 Primary Rate) -----
ISDN:
ISDN: Protocol discriminator = 08 (Q.931 user-network call control messages)
ISDN: Length of call reference = 2 bytes
ISDN: Call reference field = 00E7
ISDN: 0... .... .... .... = Message from call reference originator
ISDN: .000 0000 1110 0111 = Call reference value = 00E7
ISDN: Message type = 05 (Setup)
ISDN:
ISDN: Info element id = 04 (Bearer capability)
ISDN: Length of information element = 3 byte(s)
ISDN: Octet 3 value = 80
ISDN: 1... .... = Extension bit
ISDN: .00. .... = Coding standard (CCITT)
ISDN: ...0 0000 = Information transfer capability (Speech)
ISDN: Octet 4 value = 90
ISDN: .00. .... = Transfer mode (Circuit mode)
ISDN: ...1 0000 = Information transfer rate (64 kbit/s)
ISDN: Octet 5 value = A2
ISDN: .01. .... = Layer 1 identification
ISDN: ...0 0010 = Layer 1 protocol (G.711 u-law)
ISDN:
ISDN: Info element id = 18 (Channel identification)
ISDN: Octet 3 value = A9
ISDN: .0.. .... = Interface implicitly identified
ISDN: ..1. .... = Primary interface
ISDN: .... 1... = Only the indicated channel is acceptable
ISDN: .... .0.. = Not the D-channel
ISDN: .... ..01 = Information channel selection (As indicated in following octets)
ISDN: Octet 3.2 value = 83
ISDN: ...0 .... = Channel indicated by number
ISDN: .... 0011 = Channel/map element type (B-channel units)
ISDN: Channel number = 23
ISDN:
ISDN: Info element id = 1C (Facility)
ISDN: Length of information element = 21 byte(s)
ISDN: Octet 3 value = 9F
ISDN: ...1 1111 = Protocol profile (?)
ISDN:
ASN.1: ----- Abstract Syntax Notation One -----
ASN.1:
ASN.1: 1.1 Context-Specific Primitive [11], Length=1, Data = "<00>"
ASN.1: 1.2 Context-Specific Constructed [1], Length=15
ASN.1: 2.1 INTEGER, Length=1, Value = "1"
ASN.1: 2.2 OBJECT IDENTIFIER, Length=7, Value = "{1.2.840.10005.0.4}"
ASN.1: 2.3 ENUMERATED, Length=1, Value = "0"
ASN.1: 1.3 Universal Type 30, Length=2, Value = "<8283> (8283)"
ASN.1: 1.4 Application Constructed [12], Length=12
ASN.1: 2.1 Constructed BOOLEAN, Length=3420470
ASN.1: 3.1 Constructed GeneralizedTime, Length=48
ASN.1: 4.1 Constructed NumericString, Length=56
ASN.1: 5.1 SEQUENCE [of], Length=53
ASN.1: 6.1 Constructed VideotexString, Length=112
ASN.1: 7.1 NULL, Length=2147483647, Value = ""
ASN.1:
ADDR HEX ASCII
CALL MANAGER TO 5ESS:
DLC:
DLC:
DLC: Frame 108 arrived at 14:05:19.2893; frame size is 62 (3E hex) bytes.
DLC: Destination = DCE.D
DLC: Source = DTE.D
DLC:
LAPD:
LAPD: Address byte #1 = 00
LAPD: .... ..0. = Command/Response bit
LAPD: Control byte #1 = 00
LAPD: 0000 000. = N(S) = 0
LAPD: Control byte #2 = 02
LAPD: 0000 001. = N(R) = 1
LAPD:
ISDN:
ISDN: Call reference field = 001D
ISDN: .000 0000 0001 1101 = Call reference value = 001D
ISDN:
ISDN:
ISDN:
ISDN: Info element id = 28 (Display)
ISDN: Length of information element = 14 byte(s)
ISDN: Information = "Person X"
ISDN:
ISDN: Info element id = 6C (Calling party number)
ISDN: Length of information element = 12 byte(s)
ISDN: Octet 3 value = 00
ISDN: 0... .... = Extension bit
ISDN: .000 .... = Type of number (Unknown)
ISDN: .... 0000 = Numbering plan (Unknown)
ISDN: Octet 3a value = 80
ISDN: .00. .... = Presentation indicator (Presentation allowed)
ISDN: .... ..00 = Screening indicator (User-provided, not screened)
ISDN: Number digits = "XXXYYY7409"
ISDN:
ISDN: Info element id = 70 (Called party number)
ISDN: Length of information element = 11 byte(s)
ISDN: Number digits = "XXXYYY8055"
ISDN:
I have modified the names and calling numbers to protect the customer's identity. Any help in trying to get this work would be appreciated.
Thanks.....Darryl
Re: Name Display not working with Lucent 5ESS and Call Manager 3
calling party name is only supported on Call manager using the standard Q.931 display IE 0x28, name as facility message is not supported. If the carrier cannot supply name in standard display IE then this functionality will not be available to you.
This is what I thought. Is it safe to say that Sprint is not following the Q.931 / NI2 Speciifcations or is how they have implemented it their interpretation and is OK? Does anyone know if the 5ESS cab be configured to use the display IE versus the Facility IE? I need to get this working for my customer. Is there another ISDN Variant that could be used (and certified by Cisco) with the Lucent 5ESS?
Thanks in advance...Darryl
450
