tka
Naviguate into CCM and UC filesystem
Hi all,
Wich is the best way to naviguate in the CCM and UC filesystem. How could we the filesystem size ?
Is there any document that explains well all directory and files we could find in a CCM or Unity COnnection installation ?
Thanks in advance.
1 REPLY
Re: Naviguate into CCM and UC filesystem
there are no guides or explanation on what files are on each folder. all you can do is use the CLI file commands to browse the few directories that are available
if there is a need due to install or something, instructions will tell you were to browse
there is no real need to browse dirsystem for regular operations
java
if this helps, please rate
java
www.cisco.com/go/pdi
109
