Community Member
Need a fix for call forwarding after SRST
I have a issue with bug CSCEB24376, after an IP phone switch back from SRST mode, canceling call forwarding on the IP Phone does not work. This happens on CM 3.3.3, although the bug says it happens on 3.3.2es24. Does anyone know of a fix, instead of just a workaround?
Silver
Re: Need a fix for call forwarding after SRST
Try for a different Phone load other than what you have.
Community Member
I feel your pain here. I hate when DE's or AS engineers do not complete the DDTS entry. Since we are on the outside here is what you can do. Open a TAC case and give them DDTS #CSCEB24376. See if the TAC engineer can contact the DE that entered this DDTS to see what version this is fixed in.
HTH,
Mike
228
