Need for Overlap sending
I beleive CM 3.1 will support overlap sending on PRI interfaces to get around issues with variable length dialplans. I beleive it needs an MGCP capable PRI. Is this correct or can I use H323. If I need MGCP then which version of IOS is required. The documentaion on CCO is vague. (I intend using a 2600)
1 REPLY
Re: Need for Overlap sending
Yes, you can do this, and you need to use MGCP. Right now the only gateways you can use are DE-30+ or WS-X6608-E1. Once 12.2(2)XN is released, you can use VG200/2600/3600 with the NM-HDV-E1 cards.
88
