Need help backing up a voice gateway config
I have a vg248 and a vg224 both are running some sort of menu system on them. From my experience I can't seem to find a good way to back them up and restore them. I did find in the diagnostic menu a way to dump the configuration to screen where I can write that to a file but my customer wants the ability to dump the configuration up to a TfTp server and then back down if the device configuration gets erased.
Any suggestions?
1 REPLY
Silver
Re: Need help backing up a voice gateway config
You can just FTP the .cnf file right off the VG200 or use FTP to put the.cnf file there
90
