Need help : confusion about Fax Gateway and Fax server
I am a bit coufusion on the fax gateway and Fax server role,
I have test onramp fax on Gateway and it work fine, i can fax and recieve fax on my exchange mailbox.
1) what fax server will actually do to integrated with cisco gateway ? What feature they add ?
2) If we do MGCP backhual to CM how fax will flow ?
3) How Unity is involed in Fax ?
Appricated your help.
Natta
Anonymous
N/A
Re: Need help : confusion about Fax Gateway and Fax server
Check this link for more information on Cisco's fax server
http://cisco.com/en/US/products/ps6178/products_data_sheet0900aecd802638f9.html
Hi Nata,
Do you have any configurations that you wish to share? I am thinking of doing that on my cisco 2811 onto my exchange server.
Thank you,
paul
141
