Need help in call disconnection reason
hi all,
I have a CME version 4.1(0) on 2821 router with IOS 12.4(15)T5.
i configured the following dial-peer:
dial-peer voice 15 pots
service aa
destination-pattern 8...
port 0/2/1
and when i try to call 8320 i get a fast busy tone
i tried csim start command with debug voice ccapi inout and get the messages shown in the attachment.
Note: the service aa command under the dial peer is used for auto attendant purpose.
could any one please help me to know the reason of this?
thanks
Chad Stachowicz
Level 6
Level 6
csim start should not be used for any real testing, it can cause wierd things for wierd reasons, and I have proved csim start to be the only cause of my problems many times. Try it from a phone then resend everything if it still fails...
HTH,
Chad
Also if you tried it from a phone, was it an ip phone? I don't believe you can have that work like you want it to, unless it pots incoming dial peer. try
dial-peer peer voice 15 voip
incoming called-number 8320
session target ipv4:
codec g711ulaw
no vad
Cheers,
Chad
