Community Member
Need help on VVID
I have a Catalyst 3524XL Inline Power. The default VLAN is 1 and that is the VLAN for the IP Phones and the CCM. VLAN 120 is the VLAN for the workstations.
I have been trying to configure the switch so i am able to use the same port for the phone and the workstation. I have followed the documentation on http://www.cisco.com/warp/public/cc/pd/si/casi/ca3500xl/prodlit/cfig3_an.htm
but with no luck
Here is the config of the port:
interface FastEthernet0/1
switchport multi vlan 1,120
switchport mode trunk
switchport voice vlan 1
Int fa0/24 is a trunk to another switch.
Here are the VLANS:
VLAN Name Status Ports
1 default active Fa0/2, Fa0/3, Fa0/4, Fa0/5,
Fa0/6, Fa0/7, Fa0/8, Fa0/9,
Fa0/10, Fa0/11, Fa0/12, Fa0/13,
Fa0/14, Fa0/15, Fa0/16, Fa0/17,
Fa0/18, Fa0/19, Fa0/20, Fa0/21,
Fa0/22, Fa0/23, Gi0/1, Gi0/2
115 VLAN0115 active
120 VLAN0120 active
213 VLAN0213 active
255 VLAN0255 active
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
Thanks in advance
Community Member
Re: Need help on VVID
The example link you referenced assumes that you're going to use vlan 1 for data and something else for voice. So try this on your 3524 & see if it works...
int fa 0/1
switchport trunk encap dot1q
switchport access vlan 120
Community Member
What you are missing is the native vlan. I have pasted a working example that I use:
VLAN1 is my management vlan (10.4.66.0/26)
VLAN4 is my voice vlan (10.40.4.0/22)
VLAN81 is my data vlan (10.4.81.0/24)
All 24 FE ports can be used for Phones with PC or just a PC. The GE ports are used for uplinks.
switchport trunk native vlan 81
switchport voice vlan 4
switchport priority extend cos 0
spanning-tree portfast
interface GigabitEthernet0/1
description Uplink to PWAMatherW2SW3
interface VLAN1
ip address 10.4.66.52 255.255.255.192
Tom.
Community Member
Thanks for your reply.
Thomas this was the line that was missing in my config. Now it´s working great.
'switchport trunk native vlan 120'
Thank you very much for your help :-)
316
