Need help with CCIE Voice Lab Equipment
Hi guys,
My company plans to invest in CCIE voice equipments for employee so the budget is somewhat not a problem but I have no idea what are all required equipments for the lab after july 2006.
Here is what state on cisco web site, lab exam equipment and IOS version.
1 Cisco CallManager 4.1 (3) with latest SR
2 Cisco Unity 4.0 (5)
3 Cisco Unity Express 2.1 (2)
4 Cisco Customer Response Server /IP Contact Center Express 4.0 (1)
Please correct me if I'm wrong, in my understanding the above software can run on fast Xeon based server . they can be downloaded from cisco web site and they comes with demo license. But with new software version, Are they still be able to run on non-mcs box ? and What is the require license for each software to fulfill the lab requirement ?
5. Catalyst 6503
What line cards feature, ram , flash are required ?
6. 3725 Routers (WAN, Gatekeeper, Gateway, PSTN Emulation)
What line cards feature, ram , flash are required to make this router perform all those functions ?
7. 2651XM H.323 Gateway
What line cards feature, ram , flash are required to make this router perform this functions ? and how may routers ?
8. VG248 Analog Phone Gateway
Does it need to add more stuffs or just buy plain box ?
9. ATA186 Analog Telephone Adapters
10. CAT3550 PWR
My company has this one.
11. IP Phones
What model and how many ?
12. Cisco Unity Express Network Module (NM-CUE).
At what router this line card should be put on,
3725 or 2651xm ?
Your valuable experience will definitely be totally uesful for other candidates. I wish you can donate your spare time to write "How to build actual CCIE Voice Lab"
I greatly appreciate your help.
Thank You
1 REPLY
Re: Need help with CCIE Voice Lab Equipment
5. 6503 with a sup 2 should do.
use hybrid software on the sup
you will need a 6608 line card for t1 or e1 on this chassis.
also a 6148 or 6348 - 48 port inline power blade is preferred.
8. VG248 - You can get this box as such. You will need a amphenol connector and a patch panel to break out the RJ21 interface to rj11.
9. ata186-i1-a
11. 7960, 7940 should do.
12. you can use NM-CUE on either routers.
you may also need to get nm-16esw.
Check with IPExpert or Trinet for sample lab diagrams that they use in their lab workbooks.
Good luck.
Sankar
PS: please remember to rate posts!
173
