Community Member
need help with department attendant console
I have cominication with the callmanager, but cannot see anything on the client, need some extra configuration apart from the manual
Re: need help with department attendant console
Sounds like client trouble. Is this happen on any other console as well?
Did you try re installing and re configuring? for specific help you may want to give bit more details.
Good luck.
Baseer
Community Member
What is the issue?
136
