12-13-2005 09:47 AM - edited 03-15-2019 03:56 AM
I am new to SRST. I cannot get my phones to register with the router (2801). I think I am missing a command (maybe to activate SRST?). I haven't put in the dial peers I need yet. I'm just trying to get the phones to register with the router first. Thanks for any help. Here is my config.
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.10.100.11
ccm-manager mgcp
call application alternate DEFAULT
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
shutdown
voice-port 0/0/3
shutdown
mgcp
mgcp call-agent 10.10.100.10 service-type mgcp version 0.1
mgcp profile default
dial-peer voice 1 pots
application mgcpapp
port 0/0/0
dial-peer voice 2 pots
application mgcpapp
destination-pattern 9.......
port 0/0/1
Solved! Go to Solution.
12-13-2005 09:58 AM
All SRST configs go under call-manager-fallback mode. Additionally you need the call app alternate default command, which you already have, and also h323 based dial peers for use under srst mode.
Here are some guides to configuring SRSt on MGCP gtwy.
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a008012ecc6.shtml
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080144630.shtml
PS: please remember to rate helpful replies!
12-13-2005 09:58 AM
12-14-2005 06:39 AM
The callpmanager-fallback command was just what I was looking for. The guides where right on the spot as well.
Thanks for the help.
