Need help with SRST
I have a 2621 router running 12.1(5)YD5 with 2 FXO ports, outbound calls go out the FXO and my call manager is connected via the WAN created by a PIX-PIX VPN. When my WAN goes down, the phones go into fallback mode but do not recieve inbound calls and when I make an outbound call, I can hear the person I call but they can't hear me. My router config is:
call-manager-fallback
ip source-address 172.16.2.253 port 2000 strict-match
max-ephones 24
max-dn 24
dialplan-pattern 1 8067622... extension-length 3
default-destination 135
voicemail 500
and access-list is:
access-list 100 deny tcp any eq 2000 any eq 2000
access-list 100 permit ip any any
can anyone tell me what is wrong?
Silver
Re: Need help with SRST
Can you post the entire configs? Also what is the IP Address range of the IP Phones?
Anup
Building configuration...
Current configuration : 2356 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname lubbockvoice
logging rate-limit console 10 except errors
enable secret 5 xxxxx
ip subnet-zero
no ip finger
no ip domain-lookup
ip dhcp pool LAN
network 172.16.2.0 255.255.255.0
default-router 172.16.2.253
dns-server 172.16.1.201
netbios-name-server 172.16.1.3
netbios-node-type p-node
domain-name xxxxx
option 150 ip 172.16.3.1
voice class h323 1
h225 timeout tcp establish 1
interface FastEthernet0/0
ip address 172.16.2.253 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.2.253
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.2.254
no ip http server
snmp-server packetsize 4096
call rsvp-sync
voice-port 1/0/0
connection plar 100
signal groundStart
voice-port 1/0/1
connection plar 100
signal groundStart
no mgcp timer receive-rtcp
mgcp profile default
dial-peer cor custom
dial-peer voice 1 voip
preference 1
destination-pattern 1..
session target ipv4:172.16.3.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 102 pots
preference 1
destination-pattern 8
port 1/0/1
dial-peer voice 103 pots
preference 2
port 1/0/0
dial-peer voice 205 voip
destination-pattern 2..
codec g711ulaw
no vad
dial-peer voice 100 pots
preference 2
destination-pattern 9
port 1/0/0
dial-peer voice 101 pots
preference 1
port 1/0/1
dial-peer voice 2 voip
destination-pattern 121
voice-class h323 1
session target ras
codec g711ulaw
no vad
max-ephones 24
max-dn 24
voicemail 500
line con 0
logging synchronous
transport input none
line aux 0
line vty 0 4
password pmm01
login
no scheduler allocate
end
IP Range of phones is 172.16.2.0 thanks
does anybody see where the problem is?
Silver
You are using the access-list to block all Skinny packets to and from the IP Phones to simulate a WAN Down, right. The WAN is not actually down, right.
Because of the access-list, the phones will go to Fallback mode. But the FXO ports are setup to send calls to extension 100 and they will use Dial-peer 1 and the calls will be routed to Callmanager using H323, since H323 ports are not blocked by the access list. To the Callmanager, these phones are no longer registerd to it, that could be why incoming calls are failing. If you have Callforward busy or no answer setup for these phones, then Callmanager will send the call to that destination.
Try the same test after shutting down dial-peer 1 and see what happens.
For the one way voice with outgoing calls, try issuing this command in global mode
voice rtp send-recv
Anup
i have gone through ur config.
for inbound cal u need to metioned the dial-peer matching. i see 2 voip dial-peer , which i belive pointing to CCM.
in order to make your local router as call processing.add the following config.
destination-pattern ...
session target ipv4:172.16.2.253
codec g711ulaw
no vad
for outgoing , define this command
voice rtp send-recieve
this will work if I want the CCM to process my calls unless there is a WAN failure? I want all calls to go thru 172.16.3.1 unless the WAN fails, then I want the router here to process them.
Silver
Do you have any phone at the remote site with X 100? If yes, then this will work. Since your dial-peer 1 is 1.. and the IP phone registers as 100, when the router does the digit analysis, the phone will be matched first.
If X 100 not at the remote site now, as an alternate solution, you can add X 100 to one of the remote site phones in a different partition and setup the CSS of the gateway so that it does not include the new partition. This way when the WAN is up, the gateway cannot reach X 100 at the remote site. But when the WAN is down, X 100 will register with the SRST gateway and incoming calls will get through.
Anup
263
