NEED HLEP ON CCM UPGRADE
urgent requirement.
The question is Right now we are running CCM 3.3 on AD WINDOWS 2000. we want to upgrade Only the to AD 2003 but the ccm will remain ccm 3.3. Is it possible to do. Are there any new issues will arise if he upgrade only the AD. pls let me.
if any forum members know the answer, pls reply it. I need urgently.
esa786@gmail.com
thanks
esa
  • Other Collaboration Voice and Video Subjects
1 REPLY
Silver
Re: NEED HLEP ON CCM UPGRADE
Hello Esa,
AD 2K and 2K3 are supported for the AD integration; the problem will be if the Windows AD upgrade changes some settings like the Schema or some CCM IPT attributes or objects, my advise will be to run the AD integration again after the Windows upgrade, just in case something is changed on AD. Please follow the instructions on this link in order to check run the AD plugin.
http://cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a0080094493.shtml
Please let us now how it goes!!!
97
