Need to reset MGCP everytime the WAN connection goes down
Folks,
We have 2 callmanagers (Pub & sub) at a centralized location. Recently we have noticed after the upgrade to 4.1(3) that if the wan connection goes down we have to telnet to the WAN router at the remote site and type in "no mgcp" and then "mgcp" for it to work, by default it does not register with the callmanager. Also when it does register with the callmanager, under "show mgcp statistics", I only see one callmanager (sub) and not the publisgers IP address, any help would ne highly appreciate. I have pasted the complete config. I can ping both the callmanagers from the WAN router.
clock timezone zone 12
clock summer-time EST recurring
no network-clock-participate slot 1
no network-clock-participate wic 1
voice-card 0
no dspfarm
voice-card 1
no dspfarm
ip subnet-zero
no ip source-route
no ip gratuitous-arps
ip cef
isdn switch-type primary-4ess
voice class codec 10
codec preference 1 g729br8
codec preference 2 g729r8
codec preference 3 g711ulaw
voice translation-rule 10
rule 1 /\(.*\)/ /6590/
voice translation-profile voice
translate called 10
application
global
service alternate DEFAULT
controller T1 0/1/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
detect v54 channel-group 0
controller T1 1/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface GigabitEthernet0/0
description VLAN 1 Connection
ip address 172.20.31.30 255.255.255.0
duplex full
speed 100
media-type rj45
negotiation auto
interface GigabitEthernet0/1
description Voice VLAN
ip address 172.20.231.30 255.255.255.0
duplex full
speed 100
media-type rj45
negotiation auto
interface Serial0/1/0:0
no ip address
encapsulation frame-relay IETF
no fair-queue
frame-relay traffic-shaping
interface Serial0/1/0:0.3 point-to-point
description AT&T ePVC to IPFR
bandwidth 1024
ip address 172.20.150.129 255.255.255.252
frame-relay interface-dlci 777
class qosT1
interface Serial1/0/0:23
no ip address
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice voice
isdn send-alerting
no cdp enable
route-map Internet permit 10
match ip address Internet
set ip next-hop verify-availability 172.20.110.2 10 track 101
set ip next-hop verify-availability 172.20.109.2 20 track 100
control-plane
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
signal groundStart
timing hookflash-out 50
connection plar 6590
description FXO Hunt Group
voice-port 0/3/1
signal groundStart
voice-port 0/3/2
signal groundStart
voice-port 0/3/3
signal groundStart
voice-port 1/0/0:23
input gain 2
ccm-manager fallback-mgcp
ccm-manager redundant-host 172.20.104.5
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 172.20.104.5
ccm-manager config
mgcp call-agent 172.20.104.7 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Serial0/1/0:0.3
mgcp bind media source-interface Serial0/1/0:0.3
mgcp profile default
dial-peer cor custom
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
Re: Need to reset MGCP everytime the WAN connection goes down
no ip address
isdn send-alerting
no cdp enable
service mgcpapp
port 0/2/0
dial-peer voice 999030 pots
preference 2
service mgcpapp
destination-pattern 9T
port 0/3/0
dial-peer voice 999031 pots
preference 3
service mgcpapp
port 0/3/1
dial-peer voice 999032 pots
preference 4
service mgcpapp
port 0/3/2
dial-peer voice 999033 pots
preference 5
service mgcpapp
port 0/3/3
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999022 pots
service mgcpapp
port 0/2/2
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
dial-peer voice 99999 pots
service mgcpapp
incoming called-number .
direct-inward-dial
port 1/0/0:23
Green
Hi parwal,
Which IOS version and platform you are running.
If u can simulate the problem and paste the:
debug mgcp packet
and detailed CCM|SDL trace will be great.
You may be running into a issue with the mgcp bind command perhaps. Don't have the bug id offhand, but next time this happens gather the debugs as gogasca said and try to re-enter the mgcp bind commands as they are.
IOS version looks like 12.3(14)T or higher, which one exactly?
Folks,
Very greatful for your response. I am taking over this router from someone else who was managing it. If you notice that the bind command is missing under the serial interface, do you this this might be an issue, i will surely post the debug mgcp output.
no ip address
isdn send-alerting
no cdp enable
The isdn bind-l3 ccm-manager command is missing, what effect does that have?
Green
This command is used to bind Layer 3 of the ISDN PRI interface of the Media Gateway Control Protocol (MGCP) voice gateway to the Cisco CallManager for PRI Q.931 signaling backhaul support,
Does your T1 PRI calls work fine?
What is the sh isdn status output?
Regarding the GW try to play with this command:
ccm-manager switchback
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123tcr/123tvr/vrht_c4.htm#wp1062119
258
