Need to reset Voice Msgs id to connect to the mailbox
Users forgots thers ids to access to mailbox, I need the default ID and if it exist id recovery to force a specific id
Thanks.
Re: Need to reset Voice Msgs id to connect to the mailbox
exactly what do you mean by their id??
if my DN is 7777 then that's my id (unless you have VM box mask under the vm profile)
also you do not mention what you're using, Unity? CUC? CUE?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
I'am using UC520
the id is the code wich we must enter when trying to read messages from mailbox.
Thanks.
100
