need your help !!!! Have to exact IPCX script
I want to know how can I extract the .aef script that I'm using in my ipcx cluster. the target is to keep a copy of those script on another location (for recovery purpose).
I can I do that ? Does a copy of those script are located on the IPCX server and on the Ldap server ?
Re: need your help !!!! Have to exact IPCX script
Go to Scripts menu in IPCC admin page and you see the list of scripts. You can click the icon on to the right hand side (right most) which downloads the script to any where you want to.
When you "mouse over" this icon, it should say Download.
PS: Please remember to rate helpful replies!@
oupos I forgot to mention that the IPCX windows service actually don't goes up. I can't access to the CRS admin web page. Can I found a copy of those script some where in the file system ? I want to setup a brand new IPCX server. I have many BARS backup (with the CRS option checked) available and my LDAP is ActiveDirctory 2003. Can I just delete the "ou=CCN APPS" in my AD. Setup a new installation of IPCX and then restore a BARS backup ?
Log into IPCC server (physical login is fine) and search for *.aef in a My computer search window. It should be in a folder
C:\Program Files\wfavvid\
91
