NetMeeting and IP addresses
All,
I've an interesting situation whereby CM appears to cache IP addresses of NetMeeting clients and refuses to refresh them.
CCM is 3.12c and the CM network configuration is correct with respect to DNS/Wins, indeed pinging the clients by name/fully qualified name is succesful in all cases.
The client then logs on to net meeting and makes a call and the CM then registers their IP address, if they then move elsewhere on the network and are given a different IP address the Call manager refuses to update, however pinging from the CM is succesful.
Anyone else had a similar problem and any suggestions.
Paul
1 REPLY
Re: NetMeeting and IP addresses
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
241
