Community Member
New Problems 2.46.135
I am having problems with the web server and first voicemail port after I upgraded to 2.46.135. The web service keeps stopping with no events in the event log. The first voicemail port will not roll to the second voicemail port, callers get a busy signal on the second call. If I send callers to the second voicemail port everything rolls fine. Any suggestions?<br><br>
Gold
Re: New Problems 2.46.135
Not sure about the IIS problems...
Sounds like you have a CallManager configuration issue. Do you have CFNA and CFB defined on the Unity ports?
Keith
Keith Chambers
Unity Technical Lead
Unified Voice Team, San Jose
Cisco Systems
kechambe@cisco.com
Community Member
Are there any errors in the event logs about the IIs services shutting down?
Community Member
Yes call forwarding is configured correctly, and No there are no event errors.
Gold
What version of code are you running on the CallManager? Is it 3.1?
Keith
Keith Chambers
Cisco Systems
kechambe@cisco.com
Anonymous
N/A
I had this problem when installing 2.46.135 on CCM 1.11. Resolved by deleting the Cisco voicemail ports and then re-adding them (second time round I added the ports manually rather than with the U-One wizard.)
Try this:
Delete the ports
Restart call manager(s)
add ports one by one testing as you go along
Once you are happy that 3 or 4 ports are working as they should add the rest then test.
jim
132
