New Project ( need help )
A new Financial Bank has just introduced itself. Its plan is that, in a year they are going to open 12 new local offices.
The request is: what will the ideal Cisco Equipment will be to be implemented in the Main office.
Its planned that in the main office are going to be around 40-60 users.
Need: VPN, VoIP, PoE on LAN.
A simple help will be appreciated.
Thank You.
Hall of Fame Super Gold
Re: New Project ( need help )
If you are interested in professional guidance for the project, referencing many successful similar installations, contact me at the address present in my profile.
i think paolo has more experiance in this field i mean design and marketing
but will give just seggesion smight help
as long as they look to grow thier offices this way you need CUCM for IPTEL
version 6.1(3) good version unless u wanna go with the new version which is version 7
for gateways it depends howmany E1/T1 they will have basicly i think for small to medum 2800 or 3800 good otion
also those devices has VPN abilities but i suggest to use dffrent routers for VPN for securiy first and secondly for CPU and WORK load
for POE access layer u can get 3560 good otion with 48 port or 3750 is very good one as well
but you need to know the network design for example the access layer/ distribution layer
do the gonna hav IPS Firewalls
u can use 2800/3800 routers for security and VPN but les say ASA firewall more specialized in this one
or u may gonna have layers of security edge device router and behind it a firewall
good luck
if helps rate
130
