Community Member
Nightly Errors
I have a Unity Server that has the following error every night about 10pm. Is there a fix to this?<br><br>Event Type: Error<br>Event Source: AvRepDir_MC<br>Event Category: REPDIR <br>Event ID: 10001<br>Date: 1/9/2001<br>Time: 10:00:05 PM<br>User: N/A<br>Computer: DIABLO<br>Description:<br>REPDIR FATAL ERROR FILE H:\CommSvr\sources\reportdirector\AvRepDirSvr\AvRepDir.cpp LINE 3462 VALUE 0 <br> <br>Thanks, Ryan<br><br>
Anonymous
N/A
Re: Nightly Errors
There's been a few posts about this error... it's annoying but harmless even though it sounds like it's more serious.
This is the reports engine doing it's nightly file cleanup and looking for a particular file to delete that it doesn't find so it throws an error. This should be a warning at best and I believe it's been kicked down in 2.4.6.
It's likely looking for a fax activity log and you don't have fax installed... that's the most common scenario.
Jeff Lindborg
Unity Product Architect
Active Voice
jlindborg@activevoice.com
http://members.home.net/jlindborg
Anonymous
N/A
Re: Nightly Errors
What version of Unity is this, by the way (I need the build number as well). I'm pretty sure this is fixed... just want to make sure one of these didn't slip through.
Jeff Lindborg
Active Voice
129
