NM-1CE1B in c2620 would this work with mc3810 between two PBX?
Hello!
I have already two Alcatel 4400 PBX over MC3810 with ccs connected over E1 DVM interface at serial 0 Frame relay.
At one place it should be changed with 2620XM so wie can make CoS at 802.1q/p at fastethernet. Wie need this for VoIP over Frame relay to other 1721 at third place.
When I take NM-1CE1B in 2620 would this work with 3810 or I need NM-HDV-1E1-12 modul?
#mc3810
controller E1 1
mode ccs frame-forwarding
voice-group 1 timeslots 1-6 type ext-sig-master
interface Serial0.1 point-to-point
frame-relay class voiclass
frame-relay interface-dlci 500 voice-encap 640 voice-cir 512000
#mc3810 end
Any experience will be thanksfull accepted.
Vjeran Skribulja
  • Other Collaboration Voice and Video Subjects
Re: NM-1CE1B in c2620 would this work with mc3810 between two PB
to connect the 2600 to PBX via E1, you have to use the NM-HDV-1E1... , this NM include the DSPs to process the voice (codec).
to work between 2600 and the 3810 you can use voice over frame relay and use cisco protocol: vofr cisco, i can tell you it works very good!
Good luck, Avi.
Thanks a lot Avi.
Just small info more, what are your images you use in 3810 and 2620?
Are you use ccs?
Thanks & Merry Christmas
Vjeran
vjeran.skribulja@nextiraone.at
For the 3810 the image is 120-7.T
interface Serial0
bandwidth 128
no ip address
ip directed-broadcast
encapsulation frame-relay
no ip mroute-cache
frame-relay traffic-shaping ******
hold-queue 1024 out
no ip directed-broadcast
no arp frame-relay
frame-relay class map128 *****
frame-relay interface-dlci 16
vofr cisco
map-class frame-relay map128
frame-relay voice bandwidth 128000
frame-relay fragment 80
no frame-relay adaptive-shaping
frame-relay cir 128000
frame-relay bc 1000
frame-relay be 0
frame-relay mincir 128000
frame-relay fair-queue
And i use 3640 with ios 122-1
interface Serial2/0:1
bandwidth 128
no ip address
frame-relay intf-type dce
interface Serial2/0:1.2 point-to-point
vofr cisco
hope i it will help you, Avi
94
