NM-HD-2VE 64ms echo cancellation
Can the NM-HD-2VE support echo cancellation greater than 32 ms?
I have a customer with echo on their PRI gateway, CCM 3.3(3). In the past I have extended the echo cancellation to 64 ms to cure echo. This is the first time using this combination of hardware for PRI and I cannot find how to extend the tail coverage.
The module is installed in a 3725 with one VWIC-1MFT-T1 (PRI) and one VIC2-2FXS. The current IOS is 12.2.(15)ZJ. I also tried 12.3(4)T4 but still no echo coverage greater than 32 ms. I have tried changing the codec complexity on the voice card to medium and high, but all that did was provide less channels on the PRI.
Any suggestions are appreciated!
Re: NM-HD-2VE 64ms echo cancellation
Shawn,
The G.168 echo canceller which allows longer tail coverage was not introduced for the NM-HD-2VE until 12.3(4)XD or 12.3(7)T. If you upgrade to either of these IOS's you will have access to the extended ecan commands.
Hope that helps.
Ademola
Thanks Ademola!
The 12.3(7)T worked!
107
