Community Member
NM-HDA-4FXS and VG200?
Is the NM-HDA-4FXS is only supported in the 2600 and 3600 series? (i.e. is it also supported in vg-200's - it doesn't apear so)
Is a NM-HDV-2T1-48= or NM-HDV-1T1-24= supported in a vg200?
Even if supported are any of the above really bad ideas? :-)
- Ken
1 REPLY
Community Member
Re: NM-HDA-4FXS and VG200?
ken: we have several of the vg-200 NM-HDV-2T1-48= combination. Positive side is that we can have one piece of equipment go down and we are still protected. Downside is that you must configure each box and we run H323 so the config can get large with more complex dial-peers. And there is some pain to be found if you mix T1 lines inbound/outbound with a 5ESS tie line from IP to legacy PBX. If you are looking at alot of T1 maybe a Cat6 with a 6608 blade. I like the vg200 combo and it has been reliable. email me if you have more questions. thanks marc
95
