NM-HDV-1E1-30 voice calls issue
HI All,
     I have problem with NM-HDV-1E1-30.  When i put NM-HDV-1E1-30 in production with hardware revision number 1.0 Board Revision  : G0 then voice calls works fine, but when insert new NM-HDV-1E1-30 with hardware revision number 1.1 & Board Revision : H0 intermittent issues occurs like some of calls work smoothly. And we need to try 2-3 times to make a single call.
      What is the difference between these two hardware versions. why voice doesn;t work on higher revision number.
1 REPLY
Re: NM-HDV-1E1-30 voice calls issue
You're not really going to find anyone here that is going to know what was changed on those hardware revisions of that card.  We'd have to talk to developmers for that card to find out, but that may be a premature action at this point.
What is causing your calls to fail?  If you aren't taking L1 errors on the card during your call issues, then I wouldn't worry about the hardware revision of the E1 since everything else is done in software.
243
