No audio and disconnect on MGCP gateway
I am attempting to set up a small lab using Call Manager 4.0(2)sr2c. I have a 2621 router with a NM-2V module and two port FXO vic installed.
The FXO is connected to a single number outside line provided by telco.
I have the MGCP gateway setup and connected to CM. It routes to a specific DN that I have configured on a 7960 phone in my office.
WHen I call the number connected tot he FXO the following happens:
1. The associated 7960 phone rings.
2. If I answer the call, there is NO audio, and after exactly 16 seconds the call is disconnected and the FXO port is placed in an out of service stated (according to Real Time Monitor). I then have to shut/no shut the voice port to get it back in service.
My goal is to be able to call into this lab, receive and emulate calling into our production system. Any help would be apprecited!
Oh, I also cannot make outbound calls, but I'm figuring that is a different problem and will work them one at a time.
My 2621 config is as follows:
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname LAB-GW-DC01
enable secret 5 XXXXXXXXXXXXXXXXXXXX
enable password XXXXXXXXXXXXXXXXx
memory-size iomem 10
ip subnet-zero
mgcp
mgcp call-agent 192.168.200.1
mgcp dtmf-relay codec all mode out-of-band
call rsvp-sync
cns event-service server
ccm-manager switchback graceful
ccm-manager redundant-host 192.168.200.2
ccm-manager mgcp
interface FastEthernet0/0
ip address 192.168.200.254 255.255.255.0
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no cdp enable
ip classless
ip http server
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
voice-port 1/0/0
voice-port 1/0/1
dial-peer cor custom
dial-peer voice 1 pots
application mgcpapp
port 1/0/0
dial-peer voice 2 pots
application mgcpapp
port 1/0/1
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end
Thanks for any help!
Bryan Carter
Silver
Re: No audio and disconnect on MGCP gateway
Check if the gateway can reach the IP Phone by pinging the phone from the gateway.
Anup
hi,
during the time of call , can you see which DSP is being used.
sh dsp stat.
let me know abt this.
257
