01-29-2003 06:54 AM - edited 03-12-2019 10:28 PM
Folks,
I can't seem to get audio working in softphone. I've verified my configuration and ensured that addresses, etc. are correct. I notice one problem, and wonder if it's significant ...
I can ping my router, 10.100.1.1, my CCM 10.100.1.2, but not any phones 10.100.100.x. I can ping the phones from the CCM or the router, but not from a workstation on a different VLAN, or from a VPN client. Is there a firewall built into CCM preventing the pings, and could this be what causing my audio problems?
01-29-2003 12:17 PM
UPDATE: I can send audio from softphone, but I can't get incoming audio. If I call someone through softphone, they can hear me but I can't hear them.
01-29-2003 06:24 PM
You may want to look at the audio set up of the softphone. On the softphone, go to Settings>Audio>Network Audio Settings. Then do specify address and put the IP address of the PC/laptop you are using. I had the same audio issue when using the VPN and softphone.
Trae
01-30-2003 03:18 AM
Hi Trae. I've done that actually - I'm running over a VPN connection, and using the GETIP.ASP file to ensure that I'm getting the correct address.
01-30-2003 05:12 AM
Just got an email back from TAC (Paul - the guy who wrote the
troubleshooting book) and installing the getip.asp on CallManager is not
supported. This is because it is a web page and you would have to
modify IIS to get it to publish the page - which can affect lots of
other things.
He said you have two options:
There recommended option is to install the SoftPhone Web installer on a
web server where you can tell you users to install from. This will
automatically publish the getip.asp. Instructions are in a doc included
with the softphone download.
You can also see if you have a web server where you can just publish the
getip.asp. Obviously this will require the server administrator to
configure the web server to do this.
02-05-2003 06:17 AM
The getip seems to be functioning ok. On ALL my softphone installs (local LAN and VPN) I can send audio via mic, but I can't hear anything coming in.
02-05-2003 07:10 AM
02-05-2003 07:33 AM
That's got it!!! My DCHP scope had the router set to my CCM. When I changed it to my actual router, worked fine. Thanks!!!
