No audio in SoftPhone
Folks,
I can't seem to get audio working in softphone. I've verified my configuration and ensured that addresses, etc. are correct. I notice one problem, and wonder if it's significant ...
I can ping my router, 10.100.1.1, my CCM 10.100.1.2, but not any phones 10.100.100.x. I can ping the phones from the CCM or the router, but not from a workstation on a different VLAN, or from a VPN client. Is there a firewall built into CCM preventing the pings, and could this be what causing my audio problems?
Re: No audio in SoftPhone
UPDATE: I can send audio from softphone, but I can't get incoming audio. If I call someone through softphone, they can hear me but I can't hear them.
You may want to look at the audio set up of the softphone. On the softphone, go to Settings>Audio>Network Audio Settings. Then do specify address and put the IP address of the PC/laptop you are using. I had the same audio issue when using the VPN and softphone.
Trae
Hi Trae. I've done that actually - I'm running over a VPN connection, and using the GETIP.ASP file to ensure that I'm getting the correct address.
Just got an email back from TAC (Paul - the guy who wrote the
troubleshooting book) and installing the getip.asp on CallManager is not
supported. This is because it is a web page and you would have to
modify IIS to get it to publish the page - which can affect lots of
other things.
He said you have two options:
There recommended option is to install the SoftPhone Web installer on a
web server where you can tell you users to install from. This will
automatically publish the getip.asp. Instructions are in a doc included
with the softphone download.
You can also see if you have a web server where you can just publish the
getip.asp. Obviously this will require the server administrator to
configure the web server to do this.
The getip seems to be functioning ok. On ALL my softphone installs (local LAN and VPN) I can send audio via mic, but I can't hear anything coming in.
Bronze
That's got it!!! My DCHP scope had the router set to my CCM. When I changed it to my actual router, worked fine. Thanks!!!
401
