No audio on second Call Manger
Hello Everyone,
I have just installed a second call manager sever in a previose stand alone Call Manager Cluster(1 Sever).
When I am running on the second call manager and I place a call to an internal extension. I have about 30% failure rate on no audio.
The phone does connect to a voicemai port but no audio is heard.
Any Ideas?????
thanks
1 REPLY
Re: No audio on second Call Manger
Hello -
Have you posted this problem on the IP Telephony forum yet or contacted TAC? This sounds like a problem for TAC, especially since you just added a server to the cluster. If you do re-post, I recommend you mention the version of CallManager you are running. I'm sure they would want a detailed CCM trace from the server from where the IP phone is defined (the one you used to place the call).
Best wishes, Ginger
95
СоздатьДля создания публикации, пожалуйста в систему
