No busy tone on cme 3.3 ip phones
I am running cme 3.3 and callers to do not get a busy tone, when the destination that they are calling is busy. The call simply cuts of without the caller hearing a busy tone. I have tried using the "voice call convert-discpi-to-prog" command and it did not seem to make a difference. Do i need to reload the router after issuing this command?
Any idea how to resolve this?
1 REPLY
Silver
Re: No busy tone on cme 3.3 ip phones
You can force the gateway to generate a ring back by issuing the progress_ind setup enable 3 command. Configure this on the VoIP pointing to the Cisco CallManager.
dial-peer voice 500 voip
destination-pattern 5...
!-- Forces ring back tone for this peer.
session target ipv4:10.200.73.15
codec g711ulaw
!Note: In case of multiple VoIP peers that can be matched, make sure to configure this on all of them.
This URL should help you :
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a0080111b80.shtml
102
