NO CIRCUIT
Hi everybody,
I have a weird problem. We are terminating voip calls in a 2651 Cisco router and IOS Version 12.2(13).
The problem is that some calls get terminate but when i put the command: sh call history voice brief
i see some calls with duration and disc-cause: no circuit, and we have channels available.
There is an example:
250C : 470054hs.713 +1298 +170164 pid:0 Answer
dur 00:28:08 tx:37422/734212 rx:23193/452061 22 (no circuit.)
IP 168.251.242.201:19386 rtt:78ms pl:451020/670ms lost:14/5/21 delay:57/53/103ms g729r8
250C : 470091hs.714 +1261 +170454 pid:3 Originate 0409019515621490
dur 00:28:11 tx:23193/452061 rx:37422/734212 22 (no circuit.)
Telephony 1/0:1 (526): tx:1698020/73954/0ms g729r8 noise:-75dBm acom:29dBm
How can i fixe this problem if i have channels available???
Thanks!
Ariela
1 REPLY
Re: NO CIRCUIT
ensure that you see the channels available when you enter: sh isdn serv
Make sure there are no errors after entering: sh voice dsp
can you send a "deb isdn q931" trace
before you do, enter
voice rtp send-recv
92
