Community Member
No dial tone after pressing first digit 9
I am having a problem when I press 9 to access the dial plan, I am not getting the dial tone wav file until I press the second digit. example I press my speaker - dial tone, I press 9 - silence, I press any other digit - dialtone. All calls do go through.
1 ACCEPTED SOLUTION
Silver
Re: No dial tone after pressing first digit 9
You need to check every single route pattern and translation pattern you have that starts with a 9, and make sure that they are ALL configured to provide secondary dialtone. If you still have the problem, then you should make sure that you are not using dn's that start with 9, since they can never provide dialtone, and will break that ability.
Mary Beth
VIP Purple
Can you provide a screenshot of your route pattern configuration?
Brandon
Silver
Mary Beth
Community Member
I found that someone transposed an extension that began with 9 instead of 8. Thank you for the help.
570
