pf
Community Member
No dial-tone call forward ITS 3.01 to PBX (Ascotel 64)
The caller from outside does not get any tone if i forward my ip phone 7940 to my mobile.
All calls from outisde are coming into the PBX. PBX and ITS (Cisco 1760) are connected with a VIC-2BRI-NT/TE over Qsig.
The PBX calls my mobile via public telephony network
Silver
Re: No dial-tone call forward ITS 3.01 to PBX (Ascotel 64)
What version of IOS are you running?
Did you try adding progress_ind alert enable 8 under your pots dial peer that goes OUT to the PBX to call your mobile.
Taimoor
pf
Community Member
IOS is 12.2(15)ZJ1. Yes. I tried, but it does not help.
Peter
Community Member
you may need ansp (answer supervision) set to yes in your route data block. that would give ring back during call setup
105
