10-08-2005 11:26 AM - edited 03-15-2019 03:44 AM
- I are having issues with no dial tone when pressing the Flash button on the analog phone to transfer call. The analog phone is attached to VIC-2FXS inserted into NM-2V module of Router 2620XM. This router is running H.323 and was configured as a line gateway H.323 on CallManager 4.1(3).
I tried the below command but this issue is still exist.
voice-port 1/0/0
timing hookflash-input ...
10-13-2005 01:33 PM
check if dtmf-relay h245-signal is enabled in dial-peer config
10-16-2005 07:54 AM
I enabled dtmf-relay h245-signal in dial-peer config but the issue is still existing
