01-22-2003 09:59 AM - edited 03-12-2019 10:23 PM
We had just deployed VOIP and the issue that we are having is when a user makes a call, hears an announcement messages (for example "Enter your account number"") but cannot pass DTMF digits. This symptoms applies for both VOIP Toll-Bypass and IP Phone calls to PSTN/PBX calls. It was working for at least a week until then stop working.
01-22-2003 01:55 PM
To start, I would recommend doing some troubleshooting on your gateway. If it is an H.323 gateway, use debug voice ccapi inout to determine what the gateway is sending the PBX. I'd also take a look at your integration signalling. Is this a T1 CAS? A PRI? E&M? If it's E&M, your wink parameters may be off. It also may be helpful to have the PBX vendor to help troubleshoot their end of the connection.
01-24-2003 06:50 AM
hi,
Make sure that you have dtmf relay configured on your voip dial-peers:
"dtmf-relay h245-alphanumeric"
usually does the trick to allow out-of band signalling for DTMF.
That would help on your VOIP toll-bypass, but I am not sure about the PSTN/PBX calls.
Matt
01-24-2003 10:49 AM
If you are using an MGCP gateway, this command should work for you:
mgcp dtmf-relay voip codec all mode out-of-band
