Community Member
No 'IP' in call hist voice brief
Hi Experts,
This is the output from our 3745 IP-IP gateway. All the call routing is fine and the call terminates OK. But when I give the command 'Show call history voice brief' , It will give IP 0.0.0.0, and it is not showing which IP it is going through.
Any special configurations are required ? Please let me know if so.
AA : 112173402hs.322483 +1232 +42864 pid:1 Originate 002511370973
dur 00:06:56 tx:0/0 rx:0/0 10 (normal call clearing (16))
IP 0.0.0.0:0 rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g723r63
AA : 112216392hs.322484 +-1 +1 pid:1 Answer
dur 00:00:00 tx:0/0 rx:0/0 1F (normal, unspecified (31))
IP 0.0.0.0:0 rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 pre-ietf
AA : 112216393hs.322485 +-1 +0 pid:1 Originate 002511370973
Kiran
1 REPLY
Silver
Re: No 'IP' in call hist voice brief
I feel this is due to the bug CSCds20882. Please check the bug tool kit for more details. Hope you are familiar with the Output Interpreter tool in the Cisco.com. You can paste the output and analyse if you are missing something. It might help you pinpoint the problem.
113
