Community Member
no of calls
is there a way to check how many calls are Active at a particular time by using CCM? setup involves CCM, IP Phones...
Re: no of calls
You can use Perfmon, Select "Cisco CallManager" as the performance object and "CallsActive" as the counter. This should provice what you are looking for.
Community Member
Re: no of calls
thks. it does show the total calls. Is there anyhow I can also see how many calls are going out of the PSTN (i. eFXO card) ??
90
