No Ringback on IP phones when dialling ATA186's
We have a Call Manager version 3.1.2c with ATA186's version 2.12. ATA186 running as a H323 gateway with route patterns. If you dial from the IP phone to the ATA186 the analogue phone will ring but the IP phone will not here any ringback tone. The other direction is OK.
Can anyone help??
Re: No Ringback on IP phones when dialling ATA186's
On the dial-peer voip you need
progress_ind setup enable 3
on the Pots
dial-peer voice 200 pots
progress_ind alert enable 8
that should solve the problem
regards Philipp
Bronze
In the ConnectMode field on the ATA type i.e "00060010". You can register the ATA s also as H.323 Clients.
Good Luck
Mehmet
93
