09-18-2002 01:19 PM - edited 03-12-2019 08:50 PM
Config
CCM version 3.1.(4)
VG200 with IOS 12.2(11)T with E1 card
IP Phones <=> E1 <=> VG200 <=> E1 <=> MD110 <=> E1 <=> PSTN
we followed the document : PBX Interop. with MD 110 (E1) (documented for an 2610 router)
Problem
We do not have any ringback when calling an Ericsson Phone from an IP Phone.
We tried the different progress_ind settings, ...
After this, I configured the VG200 as an MGCP gateway, but with the same result : no ringback.
Strange thing : when we call an analog PSTN phone from an IP Phone through the Ericsson PABX, we do have ringback tone , allthough the PI is exact the same.
Please give your comments on this, if you experienced the same ...
Many Thanks
Dirk
09-18-2002 03:04 PM
Dirk: we run VG200 with NM-HDV to act as "tie" lines between our Ericsson MD110 ver 9.0 and Cisco. We go with the H323 setup and the following is a
dial-plan we use:
IP Phones <=> VG200 <=>T1 <=> MD110 <=> Ericsson Phone
dial-peer voice 1 voip
preference 1
destination-pattern [1-7]...
progress_ind setup enable 3
session target ipv4:nnn.nnn.nnn.nnn
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
codec g711ulaw
ip precedence 5
Hope this helps. marc
09-18-2002 03:06 PM
Dirk: sorry got the wrong dial-plan:
dial-peer voice 100 pots
preference 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 1/0:23
forward-digits all
09-19-2002 07:28 AM
Dirk
You might check on your VG200 Gateway configuration. there is a parameter called: Setup non-ISDN Progress Indicator IE Enable. This paramter has a note at the bottom of the page that says: May be required to force ringback from some PBX's.
You might give that a try.
09-19-2002 08:37 AM
I tried that one , no success ...
Anyway, Thanks for the feedback !!!
09-19-2002 12:22 PM
Dirk
Would you print the commands you have in the VG200 under the header MGCP.
