Community Member
Noise cancelling handsets
Looking for a noise cancelling handset to be used on a 7960 phone anyone seen such an item?
VIP Purple
Re: Noise cancelling handsets
Take a look at the following link. Choose "I need a headset for my existing phone or PDA" and then the manufacturer and model. Under Feature, check Noise Cancelling. We have several of the CS50s and have had very good success with them.
http://www.plantronics.com/north_america/en_US/productfinder/usage.jhtml
Hope this helps.
Brandon
Community Member
Brandon,
Do you guys have to use the optional lifter kit with the CS50's to allow your users to answer/place calls or how do you have your configuration set? Thanks. - Cary
VIP Purple
Cary,
We use the CS50s both with and without the lifter. The lifter makes it very handy to answer the phone if you're away from your desk, but while at their desk, our receptionists use the attendant console to answer and direct calls. So, the lifter is nice, but not required.
Hope this helps. If so, please rate the post.
Brandon
Community Member
Thanks for all the input guys, But what I am really looking for is a handset not a headset.
Scott
Community Member
I have the Cellular Headset Adapters for a Cisco IP phones. You can use standard cellular headsets with 2.5mm plug with your Cisco IP phone. I think it's much easier to find a good headset with all features you need with 2.5mm plug, than to find a specialized headset.
Michael Shavrov
www.headsetadapter.com
707
