Nortel keypad vs Cisco keypad
Below was a comment from a manager moving from Nortel Option 61c to Cisco CallManager 5.1.2, I'm don't think the "live keypad" is a feature in CallManager, if you enter a extension of another user you must press the dial button when done.
"One major loss from a user standpoint has been that the keypad is not live. In the Nortel system you could enter another phone extension 5846 and it would just dial without any additional effort, therefore calling my extension. Each user has one extra step for every call they make by pressing Dial softkey in Cisco. I am surprised that Cisco can not program the same defaults." -customer
Community Member
Re: Nortel keypad vs Cisco keypad
From my 20 years experience with Meridians, SX2000, MD110 etc thier is still a huge amount that Call Manager cannot do that a PBX can.
I also find MAC's and system admin is a lot more complicated and time consuming than with a PBX.
Unfortunately customers want to buy the latest thing which is not necessarily the best one.
I guess eventually it will get there but its a long way off yet.
Hall of Fame Super Gold
about the first comment, perhaps the customer has forgot to consider that you need to pick-up the receiver in order to do 'live keypad'. This way a cisco phone will NOT need to press dial softkey.
Of course if doing a speakerphone call, either press speaker button bfore dial, or press dial after composing the number.
Wrt to the comment about the 'legacy' being 'better' and doing 'more things', what I've found instread that features available on legacy PBX are either, poorly documented, complicated to program, rarely used.
If you are uncomfortable with MAC addresses, routing issues, and whatever else, it's exactly because in the past 20 years you are not been exposed to these. - IP telephony it's really not a big deal having just a little IP background.
All in all, I see the IPT not only has filled the gap wih legacy, but it's leading by ages now.
Go and implement something like voicemail, automatic call distribution, conferencing with legacy sysems now. Report on the amount of money and time spent. You will see there is no justifications in using legacy anymore.
Community Member
In respone to the last comment I have been working with IP for 15 years, cisco and microsoft accreditations.
I have worked with and installed CCM Unity and IPCC since around 1999.
Ths is for a number of large multi nationals and Gold Partners.
I would still say that, at the moment, legacy still has the edge in terms of funcionality and most certainley reliability.
Hall of Fame Super Red
Hi Jason,
These type of comparisons are always interesting :) As you can see from Andy and Paolo's responses people all have strong feelings about this subject. All of these systems have their strengths and weaknesses or Pros/Cons. We still run a Cisco/Nortel hybrid with about 2200 IP Phones and 300 Digital Nortel phones. I must say that our users have always "loved" the new 7900 Series phones when we migrate their departments and I have never heard this complaint. As Paolo so nicely noted the ability to pre-dial a number on your IP Phone and then either pickup the Handset, press the Handsfree/Speakerphone button or the Headset button to complete the call is so similar to Nortels "Live Keypad" it's hard to call this a mismatch. Nortels feature selects the Speakerphone automatically, so if you are using the Handset or Headset the features are in fact "exact" (I just tried this out to verify :). The other thing to note is that the "Live Keypad" feature is only available on the Nortel 3904 phone. On all other models the pre-dial feature is exact. So unless all of their users had 3904's they didn't have this functionality anyways.
To call this a "Major" loss, is, to say the least, a bit overstated.
Just my two cents!
Community Member
I agree with your comments, how you dial a call really doesnt seem that important.
To qoute one example of where funcionality is lost their is a thread currently on this forum regarding selecting PRI channels to dial out on to test them, so far no one seems to think this can be done with CCM however with a PBX this would be a very simple test to do from a handset using a trunk select short code.
I similarly , at the moment, am running a Nortel Meridian / CCM 4.1.3 Hybrid with about 4000 handsets.
Every time we have a power down the IPT is a nightmare to bring back up, the Nortel doesnt even need to be looked at, it just works !
Hey Andy,
Beleive me, I understand your comments completely :) I have also been working in the Telecom field since 1977 and with Nortel products for 25 years. This transition to IPT has been very very hard for me to say the least! But, most of these transitional problems I have to take responsability for due to my lack of understanding of the parts and peices that go into setting up and maintaining a "stable" IPT rollout. With learning comes understanding, and the realization that these "new to me" technologies require a great team with special skill sets. I have also come to understand that comparing these systems is not really comparing "apples to apples" anymore. I have learned to live with the growing pains associated with this transition.
Just for fun compare the time required for the DST change on the two systems.
Nortel 10 minutes last Spring
CCM - I hate to even think :( Still ongoing.
Again, just my two cents my friend.
Indeed from what is seen here it becomes legitimate to think that DST issues in CM are developed under the auspices of the proponents for it's abolition :)
Seriously, what is clearly happening with the CM (but CME in a part too) is that someway they lack:
1- overall responsibility of a primary customer issue by dedicated management with the needed resources to systematically locate and fix bugs to a bring software to 'very good' and consistent quality level - that is NOT the case now.
2- overall vision of all the interdependencies in the system (admittedly there are many), and coordinated coding action.
wrt the channel selection for test, I have to say, during all my years with cisco and outside, no problem on PRI has been properly diagnosed by selectively testing channels or bring them out of service. That's perhaps it's the reason no such facility exist.
Beside, I'm not even sure how you can properly test just using a steering code from handset, without looking into a trace at the same time. Suppose the calls fails, how do you know that the select B-chan wasn't simply busy at the time ?
I do agree however that the overall architecture of CCM is extremely complex and prone to failure especially when you have so many handsets to resemble a small town already. I'm positive that huge improvements should be made by Cisco in that area and the overall software quality issue.
But still I do prefer to use a product in which 99% of the issues are immediately visible to everyone rather dealing with legacy, where the documenting approach is exactly the opposite.
Nicely exposed by Rob, I've rated his valuable contribution that brings real and sensible experience, in the picture.
It is also matter of education to customers. Often they won't spend any time in reading and understanding the documentation provided, so it's up to you to get them by the hand and show how to use profitably the 'new world' telephony.
I've learn that supporting telephony requires much more patience and human skills than regular networking. Nevertheless I'm delighted by the chance and try to get the most by each customer input. In many occasion I've got new ideas, problems to look at, and even solutions by talking with customers.
I would continue, but I have to go back at the job of proper tuning a multi-group call-center, with differentiated answer hours, caller queue system, multiple trunks in and out, that makes use of both CME AA and CUE.
Try doing this admin for a legacy system, from home.
Community Member
My 2 cents worth. Been involved with Telephony since 77. Project manager for installation of first 2bESS ever installed outside the "Bell System". That 25,000 line install went a lot more smoothly than my 1000 line CCM project.
My old digital key system ran 10-years before hard drive failures took their toll and I had to move to something else. In the 10-years not one patch/hack/software change was required. Not one network change affected the "phone system".
In the first 3 months of operation of the CCM over 60 patches were applied and I am still applying monthly pathces and chasing "bugs".
The CCM is showing progress but there are
still many items that it can't do, or that require too many steps to accomplish that were simple in the PBX world.
As to remote maintenance, I have access to all of my "legacy" equipment and don't need to be on site to perform most programming jobs.
The legacy systems also don't croak if someone modifies the routing tables on the gateways, or performs an IOS upgrade in the switches or heaven forbid plugs a "router" on the network with DHCP turned on or with a looped up connection.
I like VoIP, but prefer the simplicity of the legacy systems.
Thanks Paolo,
These kind words from you mean a great deal to me :)
Back to the topic at hand:
Anyone who has ever worked with both Legacy and IPT Rollouts (especially large scale) will know that there truly is no comparison between the two when it comes to many aspects. But the truth of the matter is that the majority of Telecom dollars being spent now is going the IPT route. As Dylan once wrote "The times they are a changing" for better or worse this is the way things are :)
I get more grey hair and less sleep by the day!
