Not able to login into CUE
ssatishhk
hi,
We did the initial configuration reqiured doe Cisco CUE but not able to ping or browse the CUE web page .
here is the output of some show commands...
CUE# show software packages
Installed Packages:
- Installer (Installer application)
- Thirdparty (Service Engine Thirdparty Code)
- Bootloader (Primary) (Service Engine Bootloader)
- Infrastructure (Service Engine Infrastructure)
GPL Infrastructure (Service Engine GPL Infrastructure)
- Voice Mail (Voicemail application)
- Bootloader (Secondary) (Service Engine Bootloader)
- Core (Service Engine OS Core)
- Auto Attendant (Service Engine Telephony Infrastructure)
Instauage pack (English language pack)
CUE# show software version
Installed Packages:
- Installer 2.3.1
- Thirdparty 2.3.2
- Bootloader (Primary) 2.1.2
- Infrastructure 2.3.3
- Global 2.3.1
- GPL Infrastructure 2.3.0
- Voice Mail 2.3.2
- BoCore 2.3.0
- Auto Attendant 2.3.0
Installed Languages:
- English language pack 2.3.0
CUE#
CUE# show software licenses
Core:
- Application mode: CCME
- Total usable system ports: 16
Voicemail/Auto Attendant:
- Max system mailbox capacity time: 18000
- Default # of general delivery mailboxes: 5
- Default # of personal figurable mailboxes: 17
Languages:
- Max installed languages: 1
- Max enabled languages: 1
plz help
5 Replies 5
Chris Deren
Can you post your router configuration, specifically the service-engine interface.
Chris
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
media-type rj45
negotiation auto
no mop enabled
interface Service-Engine1/0
ip unnumbered GigabitEthernet0/0
no ip redirects
no ip unreachables
no ip proxy-arp
service-module ip address 10.10.10.11 255.255.255.0
service-module ip default-gateway 10.10.10.1
ip classless
ip route 10.10.10.11 255.255.255.255 Service-Engine1/0
i can ping 10.10.10.11 from router but not from my computer from where i would like to browse CUE web page
following is the outout of
show service-engine1/0 command
ervice-Engine1/0 is up, line protocol is up
Hardware is I82559FE, address is 0018.bacc.5570 (bia 0018.bacc.5570)
Interface is unnumbered. Using address of GigabitEthernet0/0 (10.10.10.1)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
255, rxload 1/255
Keepalive set (10 sec)
Last input 00:00:23, output 00:00:07, output hang never
Input queue: 0; Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
19948 packets input, 7426946 bytes, 0 no buffer
Received ts, 0 throttles
27702 packets output, 8302340 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 babbd
0 lost carrier, 0 no carrier
--More--
do you have:
ip http server
Also, what's the ipconfig on the workstation you're trying to use?
Are you using any kind of access-lists?
thisisshanky
Level 11
Level 11
For a min, you need the following config on the router.
int service-engine 0/0
no shut
ip unnumber fa0/0
ip route 255.255.255.255 service-engine 0/0
Ping the CUE from your router and also from another device in the network.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
