Not able to make long distance calls through T1 CAS
The gateway is a VG200 gateway.It has a T1 CAS and T1 PRI.T1 Cas is primary link to PSTN.No long distance calls can be made via this T1 cas.
It was working before.After it stopped,Vg 200 was rebooted and then it started working for sometime then stopped again.There is no problem with the service provider also.The gateway configurations are fine and it is registered with the CallManager.Is there something else we could verify or troubleshoot on.
Anupama
1 REPLY
Re: Not able to make long distance calls through T1 CAS
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
131
