11-02-2006 06:52 AM - edited 03-13-2019 03:39 PM
hi folks,
i'm stuck at one particular step in IPTX installation n i desperately need some wise solution to get me out of this.
I'm able to recieve the calls but not able to make outgoing calls hrough my E1 line i am also attacing the softcopy of my router caonfig
thanks in advance
11-02-2006 07:31 AM
hello
i'm not sure but if i understand your config, you like to do outgoing calls with dial-peer voice 1 pots...on our cme, under the dial-peer for outgoing calls, we have added the voice port, so in your case i should be port 0/1/0 so the same id like you e1 controller...
we have the following config:
dial-peer voice 100 pots
destination-pattern 0.T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/0
our user have to dial 0 to get a pstn line.
kind regards
pascal
11-02-2006 08:09 AM
thanks for your attention.
i did same config but its not working out.
can u suggest me some more from the config i have put thr.
11-05-2006 06:18 AM
NOBDY TO ANSWER THIS...
01-25-2007 12:48 AM
First of all I cannot see the D-Channel of your E1 created (Interface Serial 0/1/0:15).
NB: Make sure you have enough DSPs for the E1 channels to be created automatically when you setup the controller E1 0/1/0
I presume the following is the Dial-peer that you were hoping to use for outgoing calls:
answer-address 701
destination-pattern .T
forward-digits all
1. This can ONLY work if the calling number is from extension 701 (answer-address 701)
2. You need to assign the D-Channel on your dial-peer because as it is there is no way it will know where to go:
forward-digits all
port 0/1/0 <--- Your E1 interface
Also, the following is the minimum config for the virtual E1 interface:
isdn incoming-voice voice
I hope this helps.
