Not Able to PLAR Incomming Calls to Pilot Point
I have a pilot point setup (x5555) with hunt group (796-799). 796-799 handle our Unity Ports for AA and VM. Currently on our ICS 7750 w/ CM 3.0.8, all incommng calls PLAR to 111 (receptionists extension). Because she has no Unity subscriber account, if she does not pick up the call forwards direct to 799, then 798, .... I would like all incomming calls to go direct to AA (without ringing receptionist) through the pilot point ext 5555. I tested the extension internally by dialing it and it works, however when I assign incomming calls on a FXO or VWIC to PLAR to 5555 I get fast busy. Any suggestions would be greatly appreciated.
Re: Not Able to PLAR Incomming Calls to Pilot Point
Post your router config. It sounds like you may have a dial-peer mis-configured.
Here it is. This is for MRP in Slot 2 of ICS7750:
Current configuration : 3208 bytes
version 12.2
no service single-slot-reload-enable
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname MRP-0001966644be
logging buffered 10000 debugging
logging rate-limit console 10 except errors
no logging monitor
enable password 7 1217000305041E0F
memory-size iomem 20
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
voice-card 0
voice-card 1
ip subnet-zero
no ip domain-lookup
no ip dhcp-client network-discovery
lcp max-session-starts 0
interface FastEthernet0/0
ip address 10.2.0.5 255.0.0.0
ip access-group dhcp-block in
speed auto
ip classless
no ip http server
ip access-list extended dhcp-block
deny udp any any eq bootpc
deny udp any any eq bootps
permit ip any any
logging 10.0.0.2
logging 10.2.0.2
snmp-server community public RO
snmp-server community network RW
snmp-server host 10.0.0.2 public
snmp-server host 10.2.0.2 public
call rsvp-sync
voice-port 0/0
input gain -4
output attenuation 4
echo-cancel coverage 16
no comfort-noise
timeouts initial 5
timeouts interdigit 5
connection plar 111
voice-port 0/1
input gain -4
no comfort-noise
timeouts initial 5
connection plar 111
voice-port 1/0
input gain -4
no comfort-noise
timeouts initial 5
connection plar 111
voice-port 1/1
input gain -4
no comfort-noise
timeouts initial 5
connection plar 111
mgcp profile default
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 9
port 0/0
dial-peer voice 2 pots
port 0/1
dial-peer voice 3 pots
port 1/0
dial-peer voice 4 pots
port 1/1
dial-peer voice 5 pots
destination-pattern 911
port 0/0
prefix 911
dial-peer voice 6 pots
port 0/1
prefix 911
dial-peer voice 7 pots
port 1/0
prefix 911
dial-peer voice 8 pots
port 1/1
prefix 911
dial-peer voice 10 voip
destination-pattern 111
session target ipv4:10.2.0.2
dtmf-relay h245-alphanumeric
playout-delay maximum 300
ip qos dscp cs5 media
no vad
dial-peer voice 9 voip
session target ipv4:10.2.0.6
dial-peer voice 11 voip
dial-peer voice 100 voip
destination-pattern 1..
no vad
dial-peer voice 101 voip
destination-pattern 21..
no vad
104
