NOT Receiving name Display of IP extension when PBX phone calls
I need to verify the setup of the gateway or the RDB. When callers on PBX phones call 7960 IP phones they do not receive the name of the caller until the call is answered or goes to voice mail. Would like it to show up when the call is placed. Using a VG200 as a gateway with DM100 as primary switch type. D-channel is set with RCAP as ND2.
Re: NOT Receiving name Display of IP extension when PBX phone ca
It may be the configuration of the 7960 phones. Take a look at the following URL to see if that helps.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_0/admin_gd/3_0_5/p6phones.htm#1097557
The only section of this that would apply would be the H.323 Cient-specific devices which would be the VG200 gateway and I have alll the IE entries that apply checked. I can see the name come across on the VG200 q.931 trace.
Do you see the name in the Display IE?
If you do, run a debug MGCP packet and make sure the information is being backhauled correctly to CallManager.
Justin
I do see the name in the Q.931 trace. It is aftewr the Notify. I have attached the q.931 trace and the MGCP packet debug. How do I decifer the MGCP packet data?
Ybor-1VG200gtway2#
.Feb 6 14:42:33.120: ISDN Se1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x07
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE9808307
Exclusive, Interface 0, Channel 7
Display i = 0xB1, 'CALL PILOT WORKSTA.'
Calling Party Number i = 0x0980, '25070'
Plan:Private, Type:Unknown
Called Party Number i = 0x89, '25633'
.Feb 6 14:42:33.180: ISDN Se1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x87
Ybor-1VG200gtway2#
.Feb 6 14:42:33.180: ISDN Se1/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x87
Progress Ind i = 0x8088 - In-band info or appropriate now available
Ybor-1VG200gtway2#
.Feb 6 14:42:45.268: ISDN Se1/0:23 Q931: TX -> NOTIFY pd = 8 callref = 0x87
Notification Ind i = 0xF1
Display i = 0xB2, ' Bob Brumm'
.Feb 6 14:42:45.272: ISDN Se1/0:23 Q931: TX -> PROGRESS pd = 8 callref = 0x87
Progress Ind i = 0x8188 - In-band info or appropriate now available
.Feb 6 14:42:45.820: ISDN Se1/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x87
.Feb 6 14:42:45.844: ISDN Se1/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x
07
Ybor-1VG200gtway2#
.Feb 6 14:42:46.584: ISDN Se1/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0
7
Cause i = 0x8190 - Normal call clearing
.Feb 6 14:42:46.608: ISDN Se1/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x87
.Feb 6 14:42:46.632: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0
x07
Ybor-1VG200gtway2#
MGCP PACKET Debug:
Ybor-1VG200gtway2#debug mgcp packets
Media Gateway Control Protocol packets debugging is on
Ybor-1VG200gtway2#
.Feb 11 15:58:01.157: send_mgcp_msg, MGCP Packet sent to 10.71.40.24 --->
.Feb 11 15:58:01.157: NTFY 194663 *@Ybor-1VG200gtway2.tec.net MGCP 0.1
X: 0
O:
.Feb 11 15:58:01.161: MGCP Packet received from 10.71.40.24-
200 194663
Ybor-1VG200gtway2#
.Feb 11 15:58:16.157: send_mgcp_msg, MGCP Packet sent to 10.71.40.24 --->
.Feb 11 15:58:16.157: NTFY 194664 *@Ybor-1VG200gtway2.tec.net MGCP 0.1
X: 0
O:
.Feb 11 15:58:16.161: MGCP Packet received from 10.71.40.24-
200 194664
Ybor-1VG200gtway2#
.Feb 11 15:58:20.045: MGCP Packet received from 10.71.40.24-
CRCX 30961 S1/DS1-0/13@Ybor-1VG200gtway2.tec.net MGCP 0.1
C: D000000002002433000000008000000d
L: p:20, a:PCMU, s:off
M: recvonly
.Feb 11 15:58:20.073: send_mgcp_msg, MGCP Packet sent to 10.71.40.24 --->
.Feb 11 15:58:20.073: 200 30961 OK
I: 95F
v=0
c=IN IP4 10.71.40.7
m=audio 17568 RTP/AVP 0
.Feb 11 15:58:20.085: MGCP Packet received from 10.71.40.24-
RQNT 30962 S1/DS1-0/13@Ybor-1VG200gtway2.tec.net MGCP 0.1
X: d
R: D/[0-9ABCD*#]
S: G/rt
Q: process,loop
.Feb 11 15:58:20.097: send_mgcp_msg, MGCP Packet sent to 10.71.40.24 --->
.Feb 11 15:58:20.097: 200 30962 OK
Ybor-1VG200gtway2#
.Feb 11 15:58:31.157: send_mgcp_msg, MGCP Packet sent to 10.71.40.24 --->
.Feb 11 15:58:31.157: NTFY 194665 *@Ybor-1VG200gtway2.tec.net MGCP 0.1
X: 0
O:
.Feb 11 15:58:31.161: MGCP Packet received from 10.71.40.24-
200 194665
.Feb 11 15:58:32.157: MGCP Packet received from 10.71.40.24-
MDCX 30965 S1/DS1-0/13@Ybor-1VG200gtway2.tec.net MGCP 0.1
I: 95F
X: d
M: sendrecv
R: D/[0-9ABCD*#]
S:
Q: process,loop
v=0
o=- 2399 0 IN EPN S1/DS1-0/13@Ybor-1VG200gtway2.tec.net
s=Cisco SDP 0
t=0 0
c=IN IP4 10.71.40.5
m=audio 19400 RTP/AVP 0
.Feb 11 15:58:32.173: send_mgcp_msg, MGCP Packet sent to 10.71.40.24 --->
.Feb 11 15:58:32.173: 200 30965 OK
.Feb 11 15:58:32.701: MGCP Packet received from 10.71.40.24-
RQNT 30966 S1/DS1-0/13@Ybor-1VG200gtway2.tec.net MGCP 0.1
X: d
R: D/[0-9ABCD*#]
S:
Q: process,loop
Ybor-1VG200gtway2#
.Feb 11 15:58:32.709: send_mgcp_msg, MGCP Packet sent to 10.71.40.24 --->
.Feb 11 15:58:32.709: 200 30966 OK
Ybor-1VG200gtway2#
.Feb 11 15:58:33.753: MGCP Packet received from 10.71.40.24-
MDCX 30967 S1/DS1-0/13@Ybor-1VG200gtway2.tec.net MGCP 0.1
I: 95F
X: d
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
.Feb 11 15:58:33.765: send_mgcp_msg, MGCP Packet sent to 10.71.40.24 --->
.Feb 11 15:58:33.765: 200 30967 OK
.Feb 11 15:58:33.805: MGCP Packet received from 10.71.40.24-
DLCX 30969 S1/DS1-0/13@Ybor-1VG200gtway2.tec.net MGCP 0.1
I: 95F
X: d
S:
.Feb 11 15:58:33.833: send_mgcp_msg, MGCP Packet sent to 10.71.40.24 --->
.Feb 11 15:58:33.833: 250 30969 OK
P: PS=80, OS=12800, PR=79, OR=12640, PL=0, JI=520, LA=0
Ybor-1VG200gtway2#
.Feb 11 15:58:45.698: send_mgcp_msg, MGCP Packet sent to 10.71.40.24 --->
.Feb 11 15:58:45.698: NTFY 194666 *@Ybor-1VG200gtway2.tec.net MGCP 0.1
X: 0
O:
.Feb 11 15:58:45.702: MGCP Packet received from 10.71.40.24-
200 194666
Ybor-1VG200gtway2#
.Feb 11 15:59:00.698: send_mgcp_msg, MGCP Packet sent to 10.71.40.24 --->
.Feb 11 15:59:00.698: NTFY 194667 *@Ybor-1VG200gtway2.tec.net MGCP 0.1
X: 0
O:
.Feb 11 15:59:00.702: MGCP Packet received from 10.71.40.24-
200 194667
Ybor-1VG200gtway2#
.Feb 11 15:59:15.697: send_mgcp_msg, MGCP Packet sent to 10.71.40.24 --->
.Feb 11 15:59:15.697: NTFY 194668 *@Ybor-1VG200gtway2.tec.net MGCP 0.1
X: 0
O:
.Feb 11 15:59:15.701: MGCP Packet received from 10.71.40.24-
200 194668
Ybor-1VG200gtway2#
You are expecting "Ringing Line Presentation" instead of the "Connected on Line Presentation" behaviour. It is being reviewed as a possible future capability of Q.Sig on Call Manager 3.3.X.
You may want to review page 16 of 16.
http://www.cisco.com/application/pdf/en/us/guest/products/ps702/c1237/ccmigration_09186a00800e04ac.pdf
I had a better document with a table that described your issue, and murphy's law, I can't seem to find it. When I do I will send it you.
109
