10-15-2002 08:02 AM - edited 03-12-2019 09:10 PM
Which service parameter in CCM that I can use to adjust number of rings before going to VM? I would like change it from 5 to 3. Thanks
10-15-2002 08:13 AM
The service paramameter is ForwardNoAnswerTimeout.
This doesn't change the number of rings but the amount of time in seconds.
It defaults to 12s - about 3 rings, so 20s should do for 5 rings.
You'll need to restart the CallManager service on every server in the cluster to pick up this change.
Hope this helps.
Justin
10-15-2002 10:55 AM
This parameter took effect on my 3.1(4a) CallManager without restarting services.
