Community Member
number of Rings on IP phones
i am running call manager 3.3 with arround 250 phones. i facing a small problem on number of rings provided call manager. by default, it is only three rings then it goes vloice mail. i need phones to ring 6 times atleast, then move to voice mail.
Did anybody face this problem..? any work arround.
regards
mtaib
Bronze
Re: number of Rings on IP phones
Here you go:
Its Service->Service Parameters->Call Manager->Cluster Wide Parameters (Feature - Forward), Forward NoAnswer Timer (Sec) and set it to the time you want.
Keep in mind this is a global setting for all phones.
Geoff
Community Member
What about a local setting for the specific phones that need a large number of rings.
Rodger
Community Member
It is a cluster wide setting. Not by individual phones.
If you want more rings, forward the 1st line a second line apperance.
I don't know if they have added a feature to release 4.0 for region or phone parameters. I would think they could build it into the software of the phone and then set it via the CCM Adminstration.
Community Member
thanks Geoff,
i did what you guided. 30sec provides me exactly 6 rings.
yes, it is a global setting
taib
Community Member
Ditto - was going to suggest same.
106
